This recall? Affects all 94-98 Mustangs.
1998 FORD MUSTANG RECALL FOR PARKING BRAKE, CONVENTIONAL PROBLEM
Or did you mean a TSB?
Oil leak = rust prevention!
I've never had a rear main seal leak. Kind of funny considering how it's just kind of loosely pushed in there. When you do a rear main seal on a used crank, don't forget to sandpaper the crank a little bit to get a fresh brake in surface. Other than that, it could be a goobered up area in the main cap or the block where the seal touches.
Kurt
Can i still get this done on my car?
Also the Rear main seal is leaking a little... Im not sure if its worth dropping the trans because no matter how many i install they always seem to leak a bit.
