Underdrive Pulleys---Includes Steel UPR Crank Pulley with Bolts, Steeda 10% Overdrive Alternator Pulley and Napa 060798 Serpentine Belt
$50.00
Stock 5.0 Dipstick and Dipstick Tube
$10.00
New Antenna
$4.50
87-93 LX or Coupe Headlight Switch includes Pigtail
$40.00
87-93 Mustang Emergency Switch includes Pigtail
$40.00
E6ZR-7515-AA Clutch Fork
$15.00
M-12259-30 9.5MM Wires Black
$35.00
5.0 Air Charge Temp Sensor---Brand New
$7.00
Ignition Rotors---2 Available
$5.00 Each
E6SF-12A297-A2A Ignition Module
$10.00
E3EF-12A297-A1A Ignition Module
$10.00
Crane Cams PS-91 Ignition Coil
$25.00
Stock 5.0 Ignition Coil
$10.00
Steeda Billet Pedals ONLY 2) Gas Pedal and Dead Pedal
$18.00
Fox Body Outer Tie Rod Ends and Stabilizer Links. Links have Eurethane Bushings and also misc rubber bushings also!
$45.00
94-97 Stock 3 Bolt Fuel Pressure Regulator
$15.00
86-93 Stocl 2 Bolt Fuel Pressure regulator
$15.00
Stock Shifter Ball
$15.00
BBK Cold Air Fender Intake. NOTE! Does not include Pipe from Mass Air to Throttle Body!
$40.00
79-93 Rear Disc Conversion Parts: Crown Victoria Calipers with E-brake Cables, Custom Steeltech Solutions Mounting Brackets.
$125.00
SHIPPING IS EXTRA!
$50.00
$10.00
New Antenna
$4.50
$40.00
$40.00
$15.00
$35.00
$7.00
$5.00 Each
$10.00
$10.00
$25.00
$10.00
$18.00
$45.00
$15.00
$15.00
Stock Shifter Ball
$15.00
$40.00
$125.00
SHIPPING IS EXTRA!
