5.0 "engine tick"
BLKsteeda
236
Anywhere
Has anyone else encountered the "engine tick"? I've been reading online and it seems very very common...even with new cars driven off the showroom floor. As far as I've read tho, there hasn't been a clear cause of it.
My car is away for the winter now, but I heard it before I put it away. I was hoping I would read more about the cause by the time I pulled the car out in Spring. Build date on mine is early August, 2010.
it's all the time actually...I've heard that's it's probably a lifter issue. Since it's so widespread I'm sure Ford will have to address it at some point :shrug:
Hi BLKsteeda and tom964,
This is Deysha with Ford Customer Service. Has this issue been resolved for you yet? If not, I’d like to look into this for you. Could you please message me your dealer, mileage, VIN, and contact info?
Deysha
Deysha
Hi Deysha, no the problem hasn't been resolved yet. I haven't had my dealership look into it yet...I'm about due for my first oil change and was going to have them listen to it when I brought it in.
So i had a 2011 for a year and a half and at 10k got the tick. ford did a new timing belt, new lifters and cam phaser. They gave it back to me with the same noise. this was at 30k. once that happened i decided to just get rid of it. i traded it in on a 2012 on dec 15 2012. i just hit 7500 with my new one and i got the same tick. I just heard it today for the first time. Im beyond upset!!! any info from anyone would be appreciated... [email protected]. i have an apt on monday so ford can document it.
So i had a 2011 for a year and a half and at 10k got the tick. ford did a NEW TIMING BELT, new lifters and cam phaser. They gave it back to me with the same noise. this was at 30k. once that happened i decided to just get rid of it. i traded it in on a 2012 on dec 15 2012. i just hit 7500 with my new one and i got the same tick. I just heard it today for the first time. Im beyond upset!!! any info from anyone would be appreciated... [email protected]. i have an apt on monday so ford can document it.
Wow a timing belt on a engine that has chains that drive the camshafts.........................hmmmmmm
That's pretty much how I heard mine for the first time. It was a nice day outside, had my windows down. If you never have your windows down you would most likely never hear.it. the only time my 11 would tick at idle was after a nice long drive and if it was hot out. Then it would sound like all the videos on you tube. Make sure its documented at a dealership incase something happens. I'll keep posting on here once I get more info on Monday.
For the record: my 2014 still has 3/4 of a tank from delivery and I noticed a tick at idle when I opened the door after my 1st commute home from work. It's not there cold. I'm a little disappointed.
It's not audible in the car. It's once or twice per revolution (not multiple valves or injectors). Pretty much goes away above idle.
