92 Gt Aod Back To The Strip
last weekend I ran my new bone stock (besides CAI) 92 gt AOD and ran a 9.88 @ 72mph with a 2.2 60 ft. this weekend I ran consistent 10.04 but 2.3 2.4 60ft. I lowered the tire psi to 25lbs stick no luck. What was going wrong?
Also every track has differing amounts of traction during the day. Your 60times are showing that traction is a bit limited. If you want more consistency buy some stickier tires,work on your suspension,and a better stall converter For the trans. You should be more consistent then. Also if your diff is going out causing it to be a one-wheel wonder its going to be impossible to be hooking at all. Good luck.
Traction is either a problem or the car is just a dog off the line. My car is a 5spd but it you don't have your footwork perfect 2.1+ 60fts are easily obtained without spinning..
are you even spinning? my aod with stock stall would not even break a 255 dr loose,i actually aired it up to get spin and even then it was slight. watch your burn outs too the aod is a dog out of the hole don't get em to sticky,foot brake hard too. if all else fails shoot it with nos!! i had n/a 290 rwhp and i think the best 60 i had was a 1.9 or 2.0 with a low 14 quater and i had a shift kit ,4:10 all the rear suspension done and drag shocks h/c/i. i usually spray so i cant remember the na numbers exactly.and the dogging in third don't help either. just be gentle with her and watch the shuffle shifts.with a 75 shot i was mid twelve and thats all to do with balls off the line but was running with a permently locked converter. get a zex dry kit and hit it. best 500 bucks you can spend.
spinning bad with a 2.3 2.4 60 ft at 77mph the lower my 60 foot the lower my mph was like a 2.2 be 75mph or something like that but i might spray near future.
