anti sieze on intake mani bolts?
Anti-seize would be a good idea as stated before anywhere where steel contacts aluminum. Otherwise, you risk galvanic corrosion due to the dissimilar metals.
i would...anything I take apart gets re-assy'd with it. I'm always changing up stuff and I know dis-assy is gonna be easy if I use...just personal preference here.
I always used a little oil. Maybe next time ill use anti-seize
Yeah, the good thing about anti-seize is that it is formulated to stop the chemical corrosion created by combining stee/iron with aluminum, and unlike oil, it will be there forever, until you take it back apart.
The bad part is that anti-seize gets on EVERYTHING!
You will be so perfect with it, and make sure it gets on nothing... and when you look down, it will be on everything. :)
Your hands, clothes, fender, and anything else in the area.
