New E.T. estimate
last season my best e.t. was 9.74 at 76 mph with a 2.23 60', I have a 92 gt AOD at the time all i had done was a throttle body and cold air intake. Now i have a h pipe and flowmasters plus the 4.10 gear,master bearing kit and track lok rebuild kit and I will be soon getting a set a radials I just was curious what should the e.t. be with those upgrades.
While I can't speculate on your ET, you are headed in the right direction. Do you have a stall converter? Your best bang for your buck would be to get a looser than stock converter if you wanna see real ET's.
When the manual lever is moved in that manner it causes an accumulator pressure dump through the OD band servo which in turn causes a momentary application of the OD band. At the minimum it toasts the band. If the clamping of the OD band is severe enough it can cause sufficient shock on the mechanicals to tear up bushings, thrust washers, bearings, and planetary gears.
I only can speak from experience on one really. A buddy of mine and I beat an AOD to death doing the 1-2-1 for years. I mean at the track, street racing, always. It held up for years and although it is stationary, it still works.
