does it matter how much of the adjustment is done at the fork? I have it about halfway or a little more.. I do need to readjust that firewall adjuster again though cause the clutch is releasing too late.
It seemed today that when adjusting the FW adjuster, the lock nut was trying to turn as I turned the adjuster and the adjuster was harder to turn in either direction than it should of been. I ended up using a screwdriver to turn it. Checking a video a minute ago it seemed I should have pulled the slack out of the cable then adjust the adjuster so will try that in the morning....
thoughts guys?
thoughts guys?
