Progress Thread So check this out (exhaust problem) and progress on the 89
Sooooo,....Let me get this straight.
This started as a thread about exhaust, but also has content revolving around a "I bought this car because..........." thread.
You've stated how it has all this junk on it including a ,,,,,,,,,,(what was it,....a "perfect body and frame"?)
Meanwhile,...I look back through it and notice NOT ONE PIC!
Not a pic of a mismatched midpipe,....Not a pic of the pieces parts that made up a D.I.Y stroker kit to get 347 C.I., Not even a pic of the "perfect body or frame.
S.T.F.U. to me the next time I post something w/o them, Worthless w/o pics boy.
Reactions: 2 users
LOL Mike... fair enough. I'll get some pics today. I've got it all loaded up on a car dolly to get it down to a muffler shop either tomorrow or tues.
madmike1157
RacEoHolic330
Ok... some quick shots:
02 281 GT
This one is for you. They're ARP, 6-sided that I used a drill press to put holes in. This one ended up being too short but the ones I used are just like it (only longer).
madmike1157
RacEoHolic330
02 281 GT
So you really took the time to drill a grade 5/8 header bolt so you could safety wire them?
When I came to the south,...I used to use header gaskets and a slight smear of rtv to hold them in place ....sometimes.
After changing my first set out in front of some of my new Yay hoo friends down here, I get told to throw away the stupid header gasket, and just use black, red, copper high heat RTV (take your pick) w/o the gasket....Allow the RTV to skin, install the header, tighten the bolts, and then retighten them after a run in,...and they never leak, and they never come loose...
You boys from up North may got book learnin' You jus don't got no street smarts.:banana:
I'm tellin ya... It didn't hardly take any time at all. I spent maybe 2 minutes doing the first one and getting it lined up. Once the vise was set, it took maybe 30 seconds per bolt. So I've got maybe 15 minutes total into bolt drilling. Add another 15 minutes for the trial and error with the first bolt that ended up being too short. My step dad (that's where the car is at in the pictures) has a pretty nice press.
Ha...you've obviously never run a set of MAC headers before. Try that method with them and after a week it'll sound like you forgot to put the bolts in at all.
Ah.. MAC headers. What moron designed those with the individual flanges that never line up even?
I normally like to use 1" long allen head bolts with lock washers on all my headers if possible. Never have an issue with them backing out.
@Noobz- nice score for $2000 Sir.
When macs are new they usually line up fine.. Newbz I used a ratchet strap on the headers and heated them where the bend under the car no issues after. Fwiw your supposed to match BBK headers with their h-pipe the same with Mac
Yellow Bear racing 2k13
