After gears go in on Thursday the next step for the GT is suspension. I want to make sure it hooks up before I start getting into the top end or power adders. Right now the setup is stock (recent replacement) and a set of hotchkis rear upper and lower control arms. I think it is these http://www.hotchkis.net/7998_mustang_rear_suspension_pckg_red.html I dont know if they are any good
With the new tires (BFG Sport Comp 2s) it takes effort to break the tires and it cant even chirp on a 1 to 2 with a power shift. I know the gears will change that, but it does hook better than a worn out stock setup.
The car is primarily street use but I do want to bring it to the drag strip. I would say 90% street/10% strip and I would like it to go into the 12s. I was thinking of adding these to round out the setup
Tockico Blues
Maximum Motorsport Road and Track Springs
MM CC Plates and Bumpsteer
MM Subframes
With this setup will I need alot of motor to go 12s? I will run Drag radials at the track BTW.
I was hoping to keep the hotchkis setup if they are decent and add these other components. Let me know what you guys think.
Tockico Blues
MM Subframes
