Build Thread My Never Ending 89 Notch Thread
Sent from my iPhone using my fingers
Reactions: 1 users
Hey jeff when you get a chance could you crawl under your dash and snap some pic of how your brake switch is oriented mine gets wedged if i press the brales to hard and it will lock the brakes if i press it to hard @TOOLOW91
yesir I am taking the car to work today so I an get it for ya
Mike here is it after 40 pics it is a pain and not the best but you can see the half moon in this one
I will try and get. a better shot I left the house before the sun was up and couldn't see I will try again for you after work
Not anything huge just something on my list because I hate my plate colors so I went smoked covers
One last question how is yours oriented on the plug side just do a straight on shot like that which shows the backside of the plug
yup , if the pin isn't in it right and half moon isn't oriented right it will do what you are having happened I had the same issue when I first did my stick conversion and no brake lights cuz it kept falling
yeah well the brake lights come on but if you push the brakes hard enough the switch will start to fall down between the pedal and the steering column. oh so if the red pin isnt placed like you have yours it will stay still
you sure your not missing the white Teflon spacer that's there to keep the pressure on the whole assembly
theres a way that then the pin goes through the assembly it allows the switch to sit in the picture but it will not let it fall.
