Build Thread My Never Ending 89 Notch Thread
Ok i think mine was turned 90* so it wasnt pushing against the teflon spacer
I believe I had the same issue and with no tension it was falling , used to make for an interesting ride to work it lasted all of one day and I solved it I didn't want to get rear ended (DD status then )
Sent from my iPhone using my fingers
Got these freebies awhile ago forgot to post . Will go in over winter
So nothing that you guys will be OMG about but tonight I got in the garage and addressed an issue I had since I did the spherical bushings.
Like a dope my control arms didn't line up so instead of dropping the rear at the time I adjusted the uppers and obviously **** up pinion angle . very hard to shift didn't feel right on the street .
pulled them out tonight and reset to a factory stock upper length and re installed . What a difference ! I have mega bite jr lowers so it already plays with the pinion with the use of the holes on the brackets .
This thing spins the tires for about 50ft now in 1st and dead hooks on the street . very happy camper here
Got it down to 14.36 need to get the 60ft down waiting to make my last pass
buddys coyote car went 12.4 at 115 spinning the tires
@84Ttop here's the slip from my best pass in it so far ... and I have. had the 60ft down to 1.8 but it was a lot warmer out and this was my slowest reaction time all day fastest was .204
