cool thanks guys.... Im thinking about doing a 331 stroker... Any good kits and will it fit into my $2000 budget? I have been looking around a northern auto parts but i couldnt find any pistons that would work.... any suggestions?
If you're doing a stroker I'd go 347. I like Coast High Performance. You can get into a stroker kit for around $1700, but then you still need machining. I do think that a stroker kit is a good way to go. If you just bore, buy good pistons, put ARP bolts in the stock rods and remachine everything you will be so close to the same cost you will kick yourself. Those extra cubes are nice to have.cool thanks guys.... Im thinking about doing a 331 stroker... Any good kits and will it fit into my $2000 budget? I have been looking around a northern auto parts but i couldnt find any pistons that would work.... any suggestions?
but ive heard that a 347 will wear the engine out faster and i believe the rod pin is so high on the piston that it is in the rings... ive heard there could be problems with that setup
i see... thanks for the advice... now ill be doing a 347 stroker... any suggestions on what cam, rocker arms etc... would go with this setup?
