Tranny Cooler
The transmission people I talked with recommend running the fluid through the radiator before going to a cooler. The plan is to run the hard line to the radiator with a rubber line out of the radiator to the cooler and a hard line back to the AOD.
I agree... and defiantly in front of the radiator... that way when the air blows through your rad. then it will also go through you cooler.
I put mine here
Where the sun don't shine!!!! Haha!
what he has in mind i think will be the wrong shape. he will probably want something more, shall we say rounded for your suggestion.:p:rlaugh:
rsev216 said:
Does having it in front of the radiator affect engine temp?
not really. but the best place for a trans cooler is going to be in the coolest air stream possible, he might have to hire the fonz:D:D
That will work fine.
But I've had mine running straight to the cooler for years with no issues.
My thinking was to get all the heat out of the radiator I could.
i might take issue with that routing. transmissions want consistent temperatures, not just cool temps. and a way to get that consistent temperature is to use an aftermarket cooler that is way over sized before the cooler in the radiator. that way you get a more consistent fluid temperature back to the trans of about 210 degrees. it also helps cool the engine a bit as well.
I run an after market cooler in front of the radiator. 8" convertor on the street, temp stays at 210-220 on the exit line and 160-180 in the pan. Usually, the temps in the pan match the engine temps. I don't have an integral cooler in my radiator.
Thermostatic valve on bypass to the tranny cooler when open... forget running it through the radiator =)
It is more complicated in some ways but I like this method best personally.
If not, run it to the cooler first then to the radiator.
