SN95 Does No One Make Replacement Seat Belts For 94/95s?
Ran into this issue with the BMW. The seat belts were too worn to pass race tech. The most affordable option is to send the oem seat belts in and have them rebuild. There are companies that do this. They replace the belt itself, and fix the inertia reel. We do this with airplanes all the time.
Kurt
What do you do for belts that won't lock anymore?
My belts don't seem to catch anymore. I've tested it out by slamming on the brakes and pulling but never get them to click locked.
A quick ebay search for "mustang seat belts", then filter by year 94/95 on the check box on the left yields quite a few results.
It also groups the 96-98 belts with them, which i figured were probably the same.
Okay latest update with on going saga with finding a solution to our seat belt issue. After spending quality time talking with Ford on a call early this morning we have very few options open to us.
Option 1: Remove the lead weight ballast that engages the ratch gear lock in the the retactor ( I will post a picture of this part later). This basically removes the locking function of the retractor. Now in my case, since its the lower rectractor, its not such a big deal. But if its the upper one, you will basically run the risk of face planting the windshield/dash if the air bag does not deploy.
Option 2: Junk yard run. Again your mileage will vary. It might work for 15 more years or fail in 3 weeks.
Option 3: Adapt a seat belt from a later model year (ie 2002). This might be the path to have functioning seat belts that do what we would expect.
Option 4: Install aftermarket seats and seat belts like racing seats and 5 point harnesses
Basically it comes down to the fact that unlike a lot of parts for our model that the aftermarket picks up, seat belts were not one of them. Part of the reason is that there may be legal issues over any manufacturer providing such replacement parts. The other is most people I guess go with replacing both the seats and the seat belts to customize their cars.
It was an interesting call. I was left with this piece of advice from the engineer. If you are going to hold onto a car long term, think about picking up parts like seat belts and air bag clock springs before the car passes the 10 year mark. After that car companies are not responsible for stocking parts they rely on the aftermarket to keep the cars on the roads.
Jim
Im in the same position. Need two new belts for mine. They are frayed and they no longer lock or retract properly. Ive been looking at making these work since I have racing seats but no rollbar.
http://m.americanmuscle.com/corbeau-2in-3pt-harness.html
That or I will install a 6 pt and get harnesses. Much more costly though
I know there aren't many options for belts but a harness seems like it'd be terrible for anything other than track use. "Lemme get all strapped in so I can go grab a coke right quick."
