MY 85 GT
I run a Pro-M with mine with 42 injectrs and a 340 walbro in tank pump...500 rwhp and 14 psi...so im sure you will be fine..i do also run a snow performance stage 2 meth kit which help in tuning...
What size is the pro m meter you have now ? and was it the same with the blower setup?I run a Pro-M with mine with 42 injectrs and a 340 walbro in tank pump...500 rwhp and 14 psi...so im sure you will be fine..i do also run a snow performance stage 2 meth kit which help in tuning...
Its either a 80 or 85mm Pro-M maf..I forget which one it is..the shop that did my car supplied it,,,No my car when it was blown was still Speed density ...it ran great with the blower and an FMU and 19 lb injectors...im sure it would have ran better with a MAF conversion and a tune..but I was happy with what it was...Now its a totally different animal...What size is the pro m meter you have now ? and was it the same with the blower setup?
yeah I was just wondering cuz I can't justify 300 bucks vs 125 for a recal for 5mm more of meter I don't think it's gonna make a diff with what I am doingIts either a 80 or 85mm Pro-M maf..I forget which one it is..the shop that did my car supplied it,,,No my car when it was blown was still Speed density ...it ran great with the blower and an FMU and 19 lb injectors...im sure it would have ran better with a MAF conversion and a tune..but I was happy with what it was...Now its a totally different animal...
70mm and supposed to be getting. downs upper intake from my buddyI think you will be fine...with a 75 mm what TB are you using?...i use a 75mm BBK...with a street heat TF intake...
This setup is gonna be on a bone stock motor minus the intake . Arp head bolts , Felpro 9333 pt1 . I am shooting to make 10lbs on it like that with the power pipeThe 75mm Pro-M can only go up to a 42# inj and I find about 525fwhp...then it is a restriction. The 80mm can be calibrated to any size injector and we've pushed them to about 900fwhp.
The big thing is the way they read the air...the 80mm is much more accurate and smoother.
With a un ported gt 40 lower and even a box upper I'd say you'll be in the 420rwhp range anyway.
Pm me your price on an 80mm setup for 42sThe 75mm Pro-M can only go up to a 42# inj and I find about 525fwhp...then it is a restriction. The 80mm can be calibrated to any size injector and we've pushed them to about 900fwhp.
what's the deal with that ? I didn't really get a chance to read on it . just a sensor or is it the whole meter ?HPX slot maf and be done
