CobraWannabe
Assuming your next question is if I have power at the black/pink wire going to the fuel pump relay; I just can't seem to find a pink/black wire. I found 5 fuse links coming from the starter solenoid. All are good. Besides, I do have power at the green/yellow wire coming from the fuel pump relay (with the key in the "run" position), so my next check should be at the inertia switch, right? And that's where there seems to be a problem, because there's no green/yellow wire going to the inertia switch. And no brown/pink wire either. There's only 2 red wires. Neither side has power.
