Engine Please Help With These Afr Valves
fiveohlover
187
mn
Trying to buy new valves for my afr 185 #1387 with 11/32 stems, heads where purchased in 2005 before afr came out the the 8mm valves.
These are the part numbers i got from my valves currently
Intake 7204 http://www.summitracing.com/parts/afr-7204
Exhuast 7220 http://www.summitracing.com/parts/afr-7220/overview/
These part # have the valves listed with 2 different stem diameters and valve lengths. Can this be possible, or did AFR probably change the part# or something?
yes afr claimed they have no record of heads that old, which is a bunch crap. They said they dont even stock those 11/32 valves anymore. And i dont have a machinest nearby at all so i am trying to get info from people here. Isnt that whats stang nets for?
I used my calipers and measured and the ones i have now are the same as a Chevy valve. Summit must have there specs on the valves wrong because my valves are the same diameter and length but in the links i posted they have them listed as different lengths and stem diameters
Those valves have got to be too good to be true? $70 for a whole set of 16 valves? Must be made in china or something?
as far as i know they are made in the USA, and are stainless steel. they just dont have a name breand like manley on them. i have two sets, and they are just fine.
Not seeing any Ford valves in there in any case?
thats because aftermarket heads used chevy valves. you can also use chevy valves in a ford head if you want larger valves. or you can cut down those valves to fit the stock ford valve seats, your choice.
Tempted to run bigger valves in my GY40X's?
So you are machining the heads yourself? You have the capability to do the valve job and set the heads up completely? What about decking the surface? Just confused... Most guys don't have all of this equipment in their garage and those that do aren't on stangnet asking about what valves they need. Sorry...
