Hey i have a problem that i cant seem to identify. Here are the symptoms:
Come and go problem
grinding and creaking
Occasional scary popping/breaking sound
Sometimes slows down the car or holds it back just a bit, like a drag or like the brake is stuck even though i didnt touch the break.
And small radiator leak at center/passenger side after i turn off car
This is scary im not exactly sure but from inside i feel it coming from the drivers side wheel.
Its scary because it feels like the wheel is gonna break or something which would be disasterous on the highway.
Im gonna be driving limp mode till i fix this. A couple things to note; im no pro but i recently changed my pads calipers and rotors. Also installed an eibach swaybar, but missing the top bushing before the top nut so the swaybar is grabbing right at the nut (giggity) instead of in between 2 bushings. Also i only have 3 lugnuts on most of my wheels and idk if they even fit right. They kind of twist into the wheel. Thanks
Come and go problem
