D@mnitt, popped two today on my right rear. Fox stock rear drum 4 lug. Think they were over tighted when I got my new tires put on. Can't I jack up the rear and put it neutral and pop them out with a hammer then rotate the axel and slide the new studs through a hole somewhere? Read places where I can use washer and a larger nut as a spacer while I crank on a disposable lug nut to draw the stud in. Also read someone using a C-clamp and a long socket over thevthreads as a press and freezing the studs overnight. Anyone done these like this?? Rather do this myself, probably going to get hardend studs if I can find them.
