My 302 Build
Not sure still what the problem is. I have good spark and fuel. Replaced the ignition module and coil with no change. Most of the codes are EGR related except 13 19 and 96. Resetting the computer to see if all the codes come back.
I'm stumped. number 1 cylinder is dead but has 160psi, spark and the injector is firing. Cylinders 5 and 7 are both weak but everything checks out. Looks like I'll have to get some help figuring it out. In kinda leaning toward the computer.
Well that was not the problem. Found some hacked wires tho while swapping out computers. I have to track them all down and at least replace the speaker wire with a proper replacement. Looks like they replaced the plug ends on both relays that are by the PCM. I believe they are for the fuel pump and power for the pcm.
I didn't go back and re-read but, what codes are you showing?
Some of those symptoms you describe sound like the EEC is in limp mode.
13 19 and 96 also got a 10 but not every time. I agree I think it's in limp mode but not sure why yet and how can I tell for sure will it through a code? Oh and 2 times self test failed not even sure what that means.
Key On Engine Off test
13 ISC did not respond properly (extends to touch throttle then retracts for KOEO) – ISC
19 No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
96 Fuel pump monitor circuit shows no power – Power / Fuel Pump Circuits
I hate electrical problems.im Going to start with the code 19 when I get home. I Got a little bummed out because of all the time and money put into the motor and now it won't run right kinda sucked. It's killing me it has this new motor in it and runs like crap. I want to see how well it can run.
Ok did the check for code 19 and everything checked out. Power at both pins and the injectors. Plugged it back in and no code now, still runs like garbage. So this is what I am trying to convince my self is the problem. Testing the fuel pressure I get 34 - 36 psi running with vac line disconected. Now today I was re checking with some help and noticed when pressure gage is at 0 and the key is turned on it jumps maybe 5psi and jumps about 5-6 psi every time the key is turned on. Also it drops 1-2 psi each time as well. With the gage at 0 and turn key to run its jumps to 5 psi then turn to start it rises very slowly, it takes 5-10 seconds to reach 35psi. The car starts at about 20. Does this sound normal? I mean really it has 36 psi when it's running so does anything else matter?
Look normal? Seems to me vac should be a little higher at idle.
I'm about to put my first fuel pump in. Also my first efi build. I'm about ready to trade I'd for a carb setup...lol. That's how it goes tho. The car ran before I built the motor and first thing when we went to start it the starter wad bad. It's started the old motor just fine but was locked up by the time I was ready to hit the key.
this is with it running. It takes about 4-5 key cycles to prime to 34ish. Also takes about 5 seconds to build up when it starts. I pinched off the return line and was able to get it to 50psi. Thing is it will build the pressure up but I don't think it has the flow.
Dont trade yet. Hang in there. Ive been chasin gremlins for almost a month now. Pain in the spincter but i think its gonna be worth it.... At least it better! LOL
