How does it sound going down the road?
Like a dump truck
I got ahold of a new (used, 90%? Sure they're good
) set of coils this morning and swapped them out. Was not the issue apparently . It was all in the tune it seems.
I appreciate the offer though.
The car has NEVER gone into learn mode before tonight. Which was my own fault but again, learning.
So I get it out and fired up and up to temp and it goes into closed loop. And you can just hear it change and settle in. I was relieved.
Unfortunately when I got it out on the road the trouble persisted. Everytime I get an RPM ERROR signal, it kicks it out of learn mode and negates what the ECU is trying to do. As you can see by this helpful chart, thats a f cking lot.
Guessing a sensor has taken a dump on me.
Terrible picture but they work. sort of.
Theyre actually really neat in the way you can program them for different sensors and then the colors and ranges within that window.
I hooked the 4 gauges up to the 4 outputs and removed the fans (they werent working anyways)
Unfortunately only 2 of the gauges can be run through the output pins. BUT I can chain them all together and wire them into ONE output. Which is what Ill do. And then hook the fans back up.
Suprisingly some of the directions with the Holley are actually terrible and hard to decipher. A call to holley tech set me straight and i was able to create an ICF for the fans and gauges. Will tackle the Pinning tomorrow.
I was supposed to get a shipping confirmation on my 4.30s today, which I never got. The converter has to have more gear, which I knew already but has become very obvious. between this and the rpm error, its quite lack luster so far.
