Build Thread My First Notch Build Thread - Remember me?!
i have been apart of a few 4cyl conversions and we have never ever did a body harness. just dash, ecm and headlight harness if needed to match the year dash harness.
harness mismatches have caused a lot of headaches on the internet. to be sure, i swapped everything from stem to stern. the fuel pump relay is the problem, and he will have that problem going between 88 and 93
This is true I did mention that somewhere . It would be easier to keep it all 88 honestly and just run some mass air wires
REALLY!??! I have the conversion kit, I just thought it would be easier to just use the engine harness from a mass air car. Of course you say this after I already pulled the 88 engine harness out. So what you guys are saying is that the 93 engine harness is an absolute NO GO???
Me thinks i need to send you to the doctor for a checkup. yes moving some pins and running 4 wires for mass air is much easier and the car and harness would function like stock!
its a go if you want to add the dash harness, and body harness because the relay for the fuel pump moves to the fender apron.
Well, my logic behind using the 93 harness was that there would be no possibility of f ucking it up. But now that I see all the s hit involved with using the 93 harness I guess I'll stick the 88 harness back in and just add the wires and pins for the conversion. :bang:
unless you want to swap all the harnesses yes it would be much easier and you can find 89 140 clusters all day long on eBay or even spend some money and get the motorsport speedo ! there's a few on there right now
Too bad that $1500 is just for the turbo and nothing else probably. Nitrous it is! 2 stages of 150 or 1 progressive 300. I guess I'd have to get a nitrous specific cam tho. Oh well, we'll see how the car runs with this little 9:1 comp.
