After playing phone tag and all this I finally caught up with Kris @ all out and we may be getting something together as far as tuning this thing ASAP waiting on a call back today or tomorrow @84Ttop @93TRANSAM
it runs mint cruising never over 190 it got to 220 the other day sitting still at idle it hasn't been over 200 with the new fan clutch today or last night @my85gt
today well see mid 80s and pretty humid just like SaturdayWhat ambient temps?
yup that will be out the WindowThat's the down side to UD pullies, only benefit you when you're going fast. Not that beneficial for daily driving in stop and go.
Nick I agree on the meth part 100 percent . also as I showed you I can't understand why it would not fit with stock pulley but the tensioner sat on the pulley even with a new belt . kid I got the blower from had a cobra water pump pulley as well so I am waiting on that and I think this issue will be in the pastI avoid underdrive pulleys like I avoid the plague... Exactly as you describe it just spins the accesories slower which usually has poor results. Keep in mind that the crank pulley is now a stock size so that needs to be factored into the equation. I honestly have never had a problem fitting the stock water pump pulley on an engine with a Vortech. I know when/if you switch to an 8" crank pulley it will be really stinking close but even that clears all of the cars that I've seen/owned. With a good cooling system you shouldn't have any trouble cooling the car even while romping around town on some of the hotter days. I would advise that you be careful and become aware with your IAT's, this will tell you when the blower is heat soaked and when you need to cool off with the happy pedal. Lastly, I'm not a fan of meth injection one single bit and look at is as more of a band-aid for good fuel. I have personally seen even the "best" meth systems stop working or simply run out of fluid.... This can definitely ruin an otherwise perfectly good trip to the track or cruise to a show. You likely are not trying to squeeze every last pony out of the motor so I vote for letting it ride sans the meth injection (my .02 cents and I'm sure I'll get read the riot act for it, lol)
