Fox Anyone Use A Csr Water Neck?
LtDavis
Dirt-Old 20+Year Member
Nov 19, 2004
75
Raleigh, NC
I'm changing my thermostat and figured it'd be a good time to change to a fancy kind of thermostat housing but I want to make sure its any good before I spend the money. I tried doing a search, couldn't seem to find anything specifically about the CSR. Not interested in a cheapo chrome water neck.
Only posting link to show what I'm talking about: http://www.summitracing.com/search/Brand/CSR-Performance/Part-Type/Water-Necks
Depends on how much dress-up under the hood you eventually want to have. I've always like the ones with the AN fitting for the over flow. Like Kurt though, I have a hard time justifying a hundred bucks to have one.
If you are running a braided steel line to the radiator it's a worthwhile investment. It's still cheaper than buying an aluminum one, cutting it down and having an AN fitting welded to it.
Kurt
I agree that its expensive, but in this day and age where the US Dollar is worthless, even a small machined aluminum part is going to be expensive as hell. I'm interested if anyone actually has one of these installed, and if they have/had any problems with it. Yes its one of those little pieces just to look pretty. I figured while I'm swapping the thermostat I can take advantage and upgrade another little piece under the hood, isn't that how most of us do it?
I use a CSR water filler neck, a little different that you would be using but for what it's worth, it is top quality as far as construction goes and has worked perfectly in my application.
I seriously doubt that you will have any trouble at all with it. If you like it, get it. I'd bet a paycheck that it's a quality piece. I mean... It's CSR. :)
