Imported Item
Imported Item
New grill with floating blue oval.
Imported Item
Imported Item
I made some changes for turn signals.
Imported Item
Imported Item
Beginning wiring.
Imported Item
Imported Item
Frame looked better after I replaced all the rusty parts with good stuff & boxed the whole frame
Imported Item
Imported Item
This is what happens when you run rampant in Photoshop but I don't think 4 headlights will look all that good, even if I got the small ones
Imported Item
Imported Item
My little bead roller sure came in handy when it came time to make the firewall
Imported Item
Imported Item
Had to use part of the original fender to replace what was cut out by previous owner, luckily I had what was left of dad's truck's old fenders & grafted in what I needed, the lower rear of the fender stays on the cab, the sides would scrape on the sides of the cab when I tilted the front up
Imported Item
Imported Item
The left front fender had a bit of damage on the front of it & was leaded not bondoed so it must have happened a long time ago.
Imported Item
Imported Item
Got the overflow tank at 1 of the car shows in the area
Imported Item
Imported Item
Old "jail house bars" grill, I'm thinking of just doing a simple tube grill
Imported Item
Imported Item
This is the trailer dad welded using old batteries, my brother still has it & it is as strong as ever
Imported Item
Imported Item
The body stuff after removing it from the frame
Imported Item
Imported Item
Just some of the rust I had to replace
Imported Item
Imported Item
Some one had to replace the wooden bed some time before dad got the truck, Coke sign would be worth a lot of money if it was complete & in better shape
Imported Item
Imported Item
Old flat head seized from sitting in the field for 15 years
Imported Item
Imported Item
This is all the room I have in my garage
Imported Item
Imported Item
1965 Galaxie 390 4 barrel carb 600cfm
Imported Item
Imported Item
Custom built steering column bracket by me
Imported Item
Imported Item
GT40 Mirage windage tray
Imported Item
Imported Item
Engine getting closer to starting up
Imported Item
Imported Item
Firewall finally done
Imported Item
Imported Item
T-5 with 1941 Ford e-brake handle mounted on special bracket I made
Imported Item
Imported Item
Finally got the trans tunnel welded in
Imported Item
Imported Item
Bucket seats from a Mazda RX7
clr0gers
My hot rod project (1946 Ford pickup).
I'll try to add some photos of my hot rod from when I was working on it at different times. Not sure how this will come out, so far it has been Program 4 Chuck 1, finally got it to work.
What an awesome community!
Album information
Album owner
clr0gers
Date created
Item count
39
View count
1,499
Comment count
Rating
0.00 star(s) 0 ratings
Album privacy
clr0gers
Can view media items
Everyone
Can add media items
Album owner only
