I was driving my 2000 GT conv the other night and it started to run rough. I pulled over and it then died. I gave it a couple of minuets then tried starting it and it ran rough for 5 seconds and died again. Wouldnt start after that.... I checked fuses and safety switch in the back. I then checked the test valve on fuel rail and pressurized air came out. Cranked the engine again then nothing at all from fuel rail. I then had the car towed home I droped the fuel tank and jumped my fuel pump and it pump but got nothing without jumping power to it. I borrowed a scan tool from work but couldnt pull any codes from it. Two days before the car died I had a audio system installed. Not sure if that might have something to do with it. Now I am stuck... : / The basics I know from my troubleshooting are fuel pump is good.. power is getting to fuse, power coming out of safety switch, no fuel pressure at fuel rail, and fuel pump is not getting any power..
Also - I just installed gauges (2) and wired them through the park light switch, not sure if that was a no no or not. The car ran fine for a few hours after I installed them.
