well everyone
i recently installed that new iac valve on my bullit it ran fine for a while but now it idles to high. i cleaned the mass air flow sensor. i also disconnected the battery for about one hour and it is still idling to high. i also removed the throttle body and cleaned it. all the vacumm hoses are properly connected with no leaks. im going nuts. any more suggestions? thank you. oh it was mentioned a couple of times that i might have accidentally removed some coating from the throttle body plates. if thats the case can that be fixed or does the whole throttle body need to be replaced?
