i need clearafication on a write up you did on gear install, i had 4.10s installed by a shop and i got a pinion whine i think and the shop wont do nothing about it he says that he wouldnt warrenty anything cause i supplied the gears and nothing else but he put a new rear pinion bearing on the pinion gear and dont no why cause the other is fine but any way im gonna tear it down myself and you write is so siple accept one thing explain what pinion preload is, cause the torque specs i got is like 140ft pounds on the pinion nut but your torque specs are like 8 to 14 inch pounds please explain because i no they did a bad install.
P.S. ive rebuilt auto and man trans and ive BUILT engines that exceeded 500 hp on several occations so i no that i can do this
thinks doug
fast97gt
thinks doug
fast97gt
