1/8 mile to 1/4 mile converson?
Discussion in 'SN95 4.6 Talk' started by Demonoid, Oct 27, 2007.
  1. Demonoid New Member
    Apr 29, 2007
    Message Count:
    17
    Anyone here know what the numbers would be i ran an 1/8 mile track and did preety good i think for my first time running
    my times were
    .6920 reaction
    2.2760 60 ft
    6.3302 330 ft
    9.0369 et @594 FT
    9.6420 1/8 ET
    74.37 1/8 MPH
    it's a 98gt with a xcal2 tune,o/r H ,pypes catback,underdrive pullies,BBK upper plenum,BBK CAI ,410 gears and it's a auto!!!
    Thanx :nice:
  2. crzyhrse99 Active Member
    Mar 31, 2005
    Message Count:
    253
    28
    Kansas
  3. justinschmidt1 Member
    Jun 16, 2005
    Message Count:
    353
    well 1/4 mile would be about a 15 flat...how are you launching?
    cut the 60 to a 2.1 and you will be looking at 14.6-14.7. Might want to look into a pi swap.
  4. Demonoid New Member
    Apr 29, 2007
    Message Count:
    17
    no swap for me supercharger on the way!!!!!
  5. whyask New Member
    Apr 4, 2005
    Message Count:
    766
    Sacramento
    ya the pi swap
    1300 and youll feel a whole new car !
    check out parkway performance ! nice times for a 97 check out some slicks practice your lauching and bring your 60ft times down, once you get that in the bag everything will fall in line !
  6. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,644
    36
    UCSD/La Jolla
    i'd recomend not buying a full kit, your car's not a brand new car so brand new parts arn't required but if that's what you prefer by all means. If you shop around on parts and labor you can save anywhere from $500 to $1000 if your going aftermarket cams or ported heads
  7. mklovell New Member
    Jun 19, 1999
    Message Count:
    25
    Fremont, Ohio
    Take the 1/8 mile time and multiply by 1.55. It will be fairly close.
  8. tomustang Psychotic Member
    Jun 8, 2000
    Message Count:
    5,018
    76
    McLean Hospital
    but non-pi sucks with a blower...
    Do some research before you dip into something like a supercharger
  9. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,644
    36
    UCSD/La Jolla
    there aren't much other options due to post PI swapped heads being 10-10.5:1 compression. Porting+polishing NPI heads can if done right make them flow better than PI heads, but that's a lot of down time on a car (heads off of car for weeks). But a ported NPI head + aftermarket NPI cams (ah268's) and pi itnake manifold accompanied w/ a blower can see VERY good gains. Even if you don't alter heads tho, changing out cams + intake is a must.
  10. LI98GTStang Founding Member
    Jun 22, 2000
    Message Count:
    1,718
    36
    L.I., NY
    Friend of mine with a 97 crown vic with his NPI heads, added a vortech V2 with PI intake and PI cams dyno'd 360rwhp and recently did a 12.7 in the 1/4 mile. I like that recipe.
    Another conversion table for you.
    http://www.blownstangs.com/misc/times2.html
  11. Nuge New Member
    Oct 8, 2007
    Message Count:
    MN
    Considering I'll be running that exact setup in my Mustang that should weigh about 500 pounds less makes me a very happy guy. Can't wait till the strip opens here in the spring.
Share This Page
