Engine 11 Mpg?
Hey guys so I've actually been able to get driving around in my fox after all the work I've been doing on it. But I put a full tank in at the pump it read 12.6 gallons went in. I am almost out and have reached about 135 miles. That would be around 11 mpg. Now I'm going off of the gauge to judge empty. Maybe the gauge or odometer is wrong? The car has :
Fresh 302
GT40 upper and lower intake
Cold air intake
70 mm maf from thunderbird
BBK 70 mm throttle body.
3.73 gears
04 bullitt size wheels
Full exhaust
Direct bolted fan
And an aluminum radiator
It has all emissions removed
The car doesn't get very hot due to the direct fan which I think could be the culprit ? It is around the "A" on the "NORMAL" gauge which isnt in the middle. Im thinking it may be the fan or I need to tune for the Maf. No codes besides emissions codes. Maybe it's a fuel issue ? What should I look for ? The car is a 1992 hatch by the way. Thanks guys !
What kind of driving are you primarily doing and what thermostat are you running? Auto or manual?
I have been daily driving for the last week for the first time since buying it. I basically granny shift and never above 2k rpm. I drive to school and back which is like 20 Miles round trip. I have gotten on it once or twice the whole time I had this recent tank of gas. I am running a Fail-safe 192 degree thermostat. It could be running rich? No codes though. Also I have NO power at WOT when cruising in say 4th gear going 45 at 2500 rpm. It will SLOWLY creep up in rpms. I have never driven a foxbody or a V8 before for that matter so I don't know exactly what it should feel like but it's not good lol. I'm still in high school and don't have much help from anyone so anything is appreciated!
pull a plug and see if it is running rich. It could be a lot of things
vacuum leak
bad FPR
incorrect timing
bad O2 sensors
bad cats
crossover tubes clogged
valvetrain not set up properly
You mentioned you have a 70mm MAF from a T bird? what is the part number and what size injectors are you running
vacuum leak
bad FPR
incorrect timing
bad O2 sensors
bad cats
Okay got any ideas on where to start with an fpr? I will pull a plug and try to post a pic. You say proper valvetrain setup? Please explain more on what or why that could be. Yes the p.o installed a 70 mm thunderbird stock ford maf. I have 19# injectors. Also had a WOT relay wired in for a nos setup long time before I had the car, all was removed and fixed up but could any wiring mishap cause issues ? I'm I did a full tune up btw with ignition
vacuum leak
bad FPR
incorrect timing
bad O2 sensors
bad cats
I have the stock Maf in the barn I can throw on and see if it helps? Can the 70mm maf cause issues ? I think he did it so it didn't bottleneck but I know the pcm uses readings from the Maf to send fuel to the injectors. I'm eager to learn so let me know what you think !
Ugh. If someone tried to port it leave it alone. Find another unit. The maf is crucial abd any discrepancies Will cause poor running conditions. Almost sounds like your ecu is running in limp mode.
Well I put it on and youre right it is definitely running bad. The car runs pretty good in the lower gears it'll spin the tires no problem with the 70 mm maf but it just doesn't seem right. How can I tell if it's in limp mode ?
Just wondering but in a perfect condition, would a stock 1992 5.0 MAF work with a 70mm BBK throttle body? I would like to start over from what the P.O has done..
The MAF has nothing to do with the throttle body. For the purposes of this conversation and to keep it simple, a factory Ford MAF needs to match the EEC, and the MAF needs to match the size of the injectors . Aftermarket MAF's like PRO M can work with the stock EEC by "fooling" the EEC by adjusting the voltage sent to to the EEC.
The T Bird MAF does not have the same signal or parameters as the Mustang MAF and will cause all sorts of problems. Put a stock Mustang MAF one on or one from a 94-95 Mustang GT and see if that clears it up.
Okay cool, I was always weary about that T bird MAF.. I guess that could explain the bad mileage and power issues? We will see, I bet changing out my oxygen sensors after 132,000+ miles wouldn't hurt either. Where is the best place to get a 94-95 MAF? Its my understanding there is an adapter for the conversion? Truly appreciate the knowledgeable information.
Best place to buy one is either check the message boards or junkyards. You can either buy or fab up an adapter. By now way am I trying to whore this thread out but I I just took off a 95gt 70mm MAF off my car as I swapped to a bigger one. PM me if you are interested.
