Friend has 88GT 5 - speed and says it runs high 12.8s.. What do you think that it runs? And whats the HorsePower that he has??
Lackwood traction bars
Eibach coil overs (lowered 2 1/2")
Hotchkis upper control arms
Hotchkis front & rear swar bars
Kenny Brown subframe connectors (full length)
BBK strut tower brace
Hotchkis caster camber plates
ET street slicks
strange 31 spline axles
c-clip eliminators
Auburn posi diff
Ford Racing 3.73 gears
Ford Racing aluminum driveshaft
G-Force T5
Spec stage 3 clutch
Aluminum flywheel
E-303 Camshaft
Holly systemax II Upper and lower intake (stage 3 ported)
BBK - 75mm throttle body
C & L - 80mm mass air meter
Fenderwell K&N
Full MAC exhaust
with Flowmaster super 40-series mufflers
Aeromotive high flow rails
Aeromotive regulator (set at 39psi)
Ford Racing 36lb injectors
BBK - 255lph intank fuel pump
Ford Racing aluminum 2row radiator
Electric Fan
MSD 6AL ignition
MSD blaster 3 coil
MSD billet distributor
Moroso 11mm plug wires
Timing - 12* BTDC
16 autometer gauges
ET street slicks
c-clip eliminators
Auburn posi diff
G-Force T5
Spec stage 3 clutch
Aluminum flywheel
E-303 Camshaft
Fenderwell K&N
Full MAC exhaust
Electric Fan
MSD 6AL ignition
MSD blaster 3 coil
Timing - 12* BTDC
16 autometer gauges
