134A conversion kit
Discussion in 'Fox 5.0 Mustang Tech' started by 84blkstang, Jun 28, 2005.
  1. I saw in a magazine dont remember which one or year, and i cant seem to find it, but anyways. This 134A kit came with the compressor, lines and all the other stuff to convert a foxbody over to 134A. After searching Google :notnice: i could not find the company who makes this can someone help me out and give me a web addy or somthing.
  2. Here's some help...
    R134a Air Conditioner Conversion
    R134a = $7-$10 a can – takes 2 - 2 ½ cans.
    R134a compatible oil = $5-$7 for an 8 oz bottle – better get 2 bottles.
    Gauge set for recharging = $20-$120 – check out the pawn shops for a bargain before you pay retail.
    Vacuum pump – I use an old refrigerator compressor = $5- $20 at used appliance stores, or go to the Dump and get one for free. Be sure to have some R12 compatible oil handy to keep it lubed up properly.
    Pump to force cleaning fluid through the system $20-$50 (may use compressed air to do the same thing).
    O ring seal kit = $8.
    R134a charging adapter = $13 ( I cut mine up to use it with the R12 gauge set that I have had for a long time).
    Plastic tools to disconnect refrigerant lines - 1/2" & 5/8" = $4 each.
    Flushing agent - Discount Auto Parts has some flushing solvent in a 1 gallon plastic bottle - try that first. Or use Mineral spirits = $2 a gallon, tetrachloroethylene =$5-$10 a gallon, takes 2 gallons of either one.
    Miscellaneous hoses and fittings to adapt the flushing pump to the system, and the R134a adapter to the R12 gauge set = $15.
    I did a R134a conversion on my 89GT, and used all stock parts. You will need to replace the dryer/receiver (about $75 if you get the one with the hose made as part of the unit), and should replace all of the rubber "O" ring seals as well. You will need to drain all of the oil out of the compressor and replace it with new R134a compatible oil.
    Keep in mind that to fulfill the requirements of the EPA, you are required by law to recover any refrigerant that still remains in the system. How (or wither or not) you accomplish this is up to you. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open the valves on the gauges to dump the remaining refrigerant (if any) into your "freon recovery system", whatever it may be. Disconnect the charging gauges since you are finished with them until you are ready to fill the system with R134a. Next comes the nasty part – in order to get all the old oil out of the system, you will need to flush it with special flushing solvent, or mineral spirits (ok) or tetrachloroethylene (better, but may be hard to get). If you leave the old oil in place it will congeal and reduce the heat transfer in the condenser and evaporator (read that it won’t cool good) and possibly damage the compressor.
    Disconnect the compressor and remove it from its mount to flush it with cleaning solvent. Pour about a cup of solvent into the suction port and turn the compressor center hub about 10 turns while shaking the compressor to move the solvent around inside the compressor sump. Drain the flushing solvent out and continue to turn the center hub by hand to force out any remaining solvent. Then fill it with oil: add about 6-8 oz of the new oil to the compressor large suction fitting. Turn the compressor center hub about 20 turns as you turn the compressor face up and face down to distribute the new oil inside the compressor. Catch and replace any oil that comes out of the compressor.
    Connect the pump (I had an electric sump pump I bought for $20) to the hose from the high-pressure side of the compressor. Alternately, you could use compressed air to force the cleaning fluid through the system. I didn’t like to do this since compressed air has lots of moisture in it, which is death to A/C systems. Pump the cleaning fluid through the system and let it come out the hose that was attached to the old dryer/receiver. I used 2 gallons of mineral spirits and pumped it all through the condenser and evaporator. The expansion valve is located near the firewall in the high-pressure line of the evaporator, and may cause the cleaning fluid to trickle through the lines at a very slow pace. You may want to pump cleaning fluid through the evaporator and condenser separately to speed up the process.
    Next comes the changing of all the old "O" rings so that the chances for leaks is minimized. Use the plastic connector tools to separate the lines, place the extended collar part of the tool so that it faces the large part of the connector and push inwards: this expands the spring so that you can pull the tube apart. You may need a helper to push on the tool while you pull on the tubes to separate them. Install the new "O" rings: be sure to coat them with new oil when you put them in. Install the new dryer/receiver, R134a service port adapter, compressor, add about more 4oz of oil to high pressure line and tighten up all the lines. Close the hood, start the engine, let everything get warm under the hood, but don’t add the R134a or turn the A/C on. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open both valves, then connect the center hose to the vacuum pump. The purpose of this exercise is to heat up the system so that when you vacuum it all down (yes, you will need a vacuum pump- mine is an old refrigerator compressor), that all the air, vapor and moisture from the cleaning fluid vaporizes and is removed from the system. Vacuum it down for about 30 minutes, this should give you about 28" of vacuum or more inside the A/C system. I have a vacuum gauge "T" connected into the vacuum pump line so that I can accurately watch the vacuuming process. This is a good time to take a soda and sandwich break since it doesn’t go faster if you watch it.
    Install the R134a service fittings on the system: the red goes on thehigh side and the blue on the low side. This will help others identify that a R134a conversion has been done on the system.
    Remove the electrical connector from the dryer/receiver and jumper the two connections inside the wiring harness side of the connector together: this allows the compressor to engage in spite of low pressure/no gas in the system. Close both charging gauge valves, and then disconnect the center hose of the charging gauges from the vacuum pump and connect it to the R134a can tapper. Put the R134a can in the can tapper and screw it down with the can tapper valve closed, then open the valve. Loosen the hose at the center connection of the charging gauge set until the R134a squirts out: this purges the line of air and moisture. The refrigerant is added through the low pressure side of the system, so open the low pressure gauge valve to add the R134a. Start the car and take note of the idle speed, then set the idle speed up to about 1200-1500 rpm, and turn the A/C on inside and set the fan speed on high. Watch for the pressure on the low side to drop off as you are filling, and the R134a can will get warm and stay warm. This tells you the current can is empty and needs to be changed for a fresh one. Before you disconnect the can, be sure to close the valve on the R134a can tapper.
    Watch the high side pressure on the charging gages and regulate the adding of gas to keep the high side pressure under 350 psi. You will probably need a fan in front of the car to keep the readings below 350 psi. I had to put the R134a can in hot water while I was charging the system with it, or else the can got so cold that it quit flowing. Use caution when you do this so that you don’t get water in the charging adapter when you change the cans. When you have added the 2 cans of gas, the high side will read about 250-300 psi and low side about 28-38 psi. Turn the idle speed back to where it was, turn the A/C off, disconnect the charging gauges, and re-install all the caps on the service ports. Remove the jumper from the low pressure switch harness and plug it back on the switch connectors. Then put the R134a Service Sticker on, secure all the loose wiring on the system and you are done. I
    The above technical note is for informational purposes only, and the end user is responsible for any damages or injury. The end user bears all responsibility for proper recovery/disposal of any R12 refrigerant.
    I have an EPA 609 MVAC certification. And yes, you can shortcut the process, but there are negative factors if you do. Sooner or later, something will cease to function like it should. Shoddy work is a time bomb ticking away, waiting to explode.
  3. see the problem is that i only have the compressor i dont have any lines or anything else, condensor or the thing that goes in the heater box either. This was all gone when i got the car i just figured it was better to put the new stuff in than piece everthing together
  4. jrichker - wow, that was one heck of a detailed instruction. Since you seem to know alot about refrigerant systems, I have a question.
    I have a 134a gauge cluster and I'm not sure what pressures I should be reading on the high and low pressure side when there is enough refrigerant in the system.
    If I'm going by pressure, are those numbers make and model independent for the most part? Whereas the refrigerant volume in the system will vary from model to model.
  5. 84blkstang -
    Hose Wizards out of Georgia. If you take it there he will even install for free. If you do order, know that the instructions are "cheap" at best. If you do go that route let me know and I will help with instructions. You will still need an A/C-Heater box with evaporator, controls and ducting for the interior of the car. Rape a JY beauty for some of this.
    http://www.hosewizards.com/
    For another writeup on a conversion, see...
    http://www.veryuseful.com/mustang/tech/general/R12-to-R134A-Conversion.html
  6. The pressures will vary from one car to the next, with outside air temp, and refrigerant charge level, so any pressure figures I would post probably wouldn't be of much use. I have been getting 200-250 PSI high side and 26-38 PSI low side at 1500 RPM with 83-87 degree outside air temp. My car is slighly undercharged when compared to the standard charge for R134a, but it works good, so I'm happy.
    The text book answer for refrigerant charge is 80% of the original R12 charge. This means less refrigerant will be used when charging systems converted to use R134a .
    Example: 42 ounces of R12 x 80% = 33.6 ounces of R134a. That's about 2 1/2 cans. That's R134a only and does not count the oil charge, which is a separate item.
  7. does anyone know how much this kit runs and how well it works?
  8. I am very interested in this as well. I have a January 2003 5.0 Mustang magazine with an article/instructions on Hose Wizard Kit. It says that it cost $699 bucks.
    It includes everything you need to convert from r12 to r134a properly. A new condensor, a Sanden compressor, compressor mounting brackets, a serpentine belt, a high pressure cut-out switch, and all hoses and fittings. In the install article it says they replaced all that except the evaporator and cycling pressure switch.
    If you have questions I will try to find out in the article. It seems like a fairly simple swap (relatively speaking)...
    This is from the article: "The typical 87-93 Mustang R-12 A/C system sees dash-vent temperatures in the 40-42* range on fan speed one. However, when a basic R134a conversion is done (a simple change of refrigerant and oil), the dash outlet temps climb to 49-50 degrees. If you turn the fan speed higher, you lose 2-3*'s per speed, only making it worse. With the Hose Wizard R134a conversion, outlet temps hover in the 35 degree range on fan speed three!":nice:
    I need money first...:bang:
    Edit: Lol...look what I found after going to their website and typing that out real quick. The actual article I have.
    http://www.hosewizards.com/articles.htm
  9. $699
    (edit) Oops, I see the price was listed.
    A guy here did it on his 89. He likes the vent temps that he gets. That is the only experience that I have to share.
  10. I noticed an "R134a Retrofit Kit" for sale in the most recent Advance Auto Parts newspaper advertisement insert.
    Would this work? Or do you need to do other steps mentioned in the numerous postings about doing the conversion yourself?
  11. Commonly referred to as a "Death Kit".
    Some have used it with decent results, others like to do a job right.
  12. So if I bought the Hose Wizard kit would I need those parts for my 93 stang?
  13. "Doing the job right" is one thing - but when you weigh the cost of the $30 retrofit kit vs. the $100+ for the full conversion, it seems to me that you could try the "several hour project" for less money, if it works, great, if it doesn't, you spend the extra money and do the "weekend job".
  14. 5sp GT - Yes, you will. The Hose Wizards kit is for a Fox car that already has A/C installed (R12) that wants to convert to R134A.
    criticman -
    Doing the job right the first time is an attitude. People with this attitude would rather do the job right the first time and make it a quality job using quality components. With the attitude of "if it works - great", I have to ask you why you have all of this...
    "Strut Brace, Headers, O/R H-pipe, Magnaflow Catback, CAI, C&L 76mm MAF & TrueFlow pipe, 70mm Accufab TB, Cobra Intake, Tokico Shocks & Springs, Steeda Caster Camber, King Cobra Clutch, Underdrive Pulleys, Triax, AFM PMS and more.
    2B installed: 3.55's, Granatelli Control Arms, Pinion Snubber, Offset Rack Bushings, Subframe Connectors, Gtrac Bar, battery relo."
    It would seem to me that your 93 was working just fine before you spent all of that "extra money".
  15. There must be a reason it is called a "death kit".
    It seems that there is always enough money to fix something you just got through fixing. Maybe it would have been less expensive to do it right the first time.
    Unfortunately, A/C work requires some tools that aren't cheap and probably aren't available for loan at the local auto parts house. I don’t recall seeing a vacuum pump on the loaner tool list last time I went to Autozone. On the other hand I got the last refrigerator compressor I use for a vacuum pump for free. A set of charging gauges from Harbor Freight will cost you $63 ( http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=2435 ). The same set is available from Autozone, but I don't remember the price.
    Either you bite the bullet and purchase the tools as an investment in future savings or you pay to have it done. I have been fixing the A/C systems on my own cars for many years now, so any money I spent on tools has been made up in savings many times over.
  16. Oh okay so your response about needing those parts was just for 84stang. The Hose Wizard comes with everything I need in that $699 kit?
  17. like 5spdgt said is there anything else required besides what is contained in this kit? My car came with Ac but the condensor, and lines and the stuff in the heater box is gone, all that is left is the AC compressor
  18. 5sp GT - Er, yes, sorry. I was reading that 84blkstang had a car that came without A/C. I am now seeing that it did have A/C, yet he needs an evaporator ("the thing that goes in the heater box"). The Hose Wizard kit will have everything that you need. You will want to "pop flush" the evaporator.
    84blkstang -
    You will need an evaporator (I recommend Autozone that has the best price for a Factory Air piece which I will buy here for my 89) and an LPCS (Low Pressure Cycling Switch - Ford). I've pulled my heater box 4 times to replace the heater core so far on my 84. Not a terrible job.
  19. How about the R134a gas for one thing. PAG or Ester oil for another. I also suggest adding some UV tracer dye when recharging. It will aid you in finding leaks down the road.
