Depending on your offset in the front, 17x9s will most likely rub. I have a 24mm offset on 17x9s and they rub pretty bad stop to stop on turning - metal to metal bad. My rears are the same offset and I had to roll the fender lip to clear for when the body runs on turns. I also removed my rear quads, so i don't have to worry about the inner side rubbing.
17x8s or smaller with a 24mm or less offset will work best. I think a 17x9 with a 0 offset wouldn't rub on the inner part of the wheel...but the rim might stick out past the fender, which is never good.
