1987 gt dyno woes :(
Discussion in 'Fox 5.0 Tuning' started by thebuckaman, Jul 11, 2006.
  1. thebuckaman New Member
    Jul 10, 2006
    Message Count:
    39
    Hey all,
    Just had my 1987 Mustang GT 5-speed dynoed after a bunch of work- 306 keith craft, federal mogul pistons, AFR heads, roller rockers, bbk long tubes, bassani x-pipe, flowmaster cat-back, C&L intake, 75mm MAF, 70mm throttle body, 24lb inj, cam, edelbrock upper and lower, and full Accel ignition.
    Grand total after chip and "dyno tune"...291 rwhp!?
    That just seems low to me. Anybody have any insight into this? Car runs great, but I thought there was more there after all the mods.
    What can I do to eek some more out of her? timing? Any suggestions. I also dont feel like the shop did a great deal of "tuning" while i was there.
    Thanks,
    Carl
  2. DMAN302 My mom says thanks for the pearl necklace.
    Nov 8, 2003
    Message Count:
    2,392
    98
    58
    Sounds just about right...I left my session with 291/316 and was disapointed too. It wasn't untill I spent some real time looking at 302/306 combo's that I found high 285-305 to be the average with near every combination..though some guys always tend to post killer numbers they are not the standard by a long shot. To tweek you could look at an Efan and a more aggressive tune with maybe a higher octane fuel..both of which I am now running and expect to see 300 on the next set of pulls in the fall. Don't be disapointed...dyno numbers are just numbers..you might be 15 higher next time for no reason at all...they are great tuning items but do not represent what the car is able to do.
  3. airbag New Member
    Aug 17, 2005
    Message Count:
    55
    what cam?
  4. thebuckaman New Member
    Jul 10, 2006
    Message Count:
    39
    Comp Cams 35-324-8 hydraulic cam
  5. speedytang Founding Member
    Jul 28, 1999
    Message Count:
    893
    I am shocked because that seems 20 rwhp high to me.
  6. DMAN302 My mom says thanks for the pearl necklace.
    Nov 8, 2003
    Message Count:
    2,392
    98
    58
    Same cam I run...your lookin just about right to me.
  7. QDRHRSE New Member
    Dec 31, 2002
    Message Count:
    1,603
    Looks reasonable.
  8. SMOKEDYA Well-Known Member
    Jul 13, 2003
    Message Count:
    3,604
    56
    Seems weird to me ? I have a 302 with gt40p's ported and polished cobra intake ported extrude honed and all the bolt ons l/t's mac pro chamber elec fan griffen alum rad. My car dyno 310 and 338 on a dyno jet. peace
    john:p
  9. enyawix New Member
    Dec 18, 2005
    Message Count:
    489
    SMOKEDYA what cam, lifters, and roler rockers? What size injectors?
  10. N8Miller I need NOS....make it 2 of the big ones
    Jul 26, 2000
    Message Count:
    2,685
    is it a 302 motor?
  11. 88Stang331 New Member
    Mar 30, 2006
    Message Count:
    245
    Just curious as to what the difference is between a Mustang dyno, and a Dynojet. I Dynoed 270/290 at the rear wheels with the items in my sig on a mustang dyno.
  12. gcwh02 New Member
    Jun 20, 2005
    Message Count:
    523
    supposivly the numbers will be a little lower on the mustang dyno but they tune your car based on the weight and everything(correct me if im wrong)
  13. SuperStang83 Founding Member
    Mar 21, 2001
    Message Count:
    1,774
    48
    Thats good though, about 340 at the flywheel!
  14. VG30DE Founding Member
    Sep 17, 2002
    Message Count:
    442
    I built a 302 stock shortblock from a '01 mountaineer, GT40 cobra heads ported and polished, stock mustang gt cam retarded 4 degrees, 1.72rr's, cobra R intake, 30# injectors, 75mm tb and maf, bbk headers, pro chamber..... put it in a 95 gt, no tune, dynoed in at 281 horse 315 tq at the wheels, so I think that you're still a little low......
  15. C0V3R Member
    Feb 14, 2003
    Message Count:
    525
    Looks like its in the right ball park. Maybe a bit more to be had somewhere. Did you get AFR's with the sheet?
  16. OrLackThereof New Member
    Mar 10, 2003
    Message Count:
    563
    Are you kidding me? Thats high compared to what I usually hear! In the mustang club Im a member of, in the county, I have the second highest NA 5.0 DD numbers in the club at 268, the highest guy pushes like 275, but on a 5-speed versus my AOD. Youre doing fine. But I do believe there is more to get out of your combo, you have really good parts.
    Post a dyno chart, with air/fuel. I'll bet you can tweak the A/F and timing and one or two other little things, and get some better numbers out of it.
  17. thebuckaman New Member
    Jul 10, 2006
    Message Count:
    39
    I am planning on taking the car to Anderson Ford Motorsports for a tune. I think they will be able to tune my car a bit more effectively than the shop I went to initially.
    thanks guys
  18. OrLackThereof New Member
    Mar 10, 2003
    Message Count:
    563
    DOUBLE POST
  19. OrLackThereof New Member
    Mar 10, 2003
    Message Count:
    563
    Can't say I'd expect to be finding much more power in an eec-4 system....unless they go through the tune with a fine-toothed comb and tweak the fuel and timing line by line and that kind of labor time is gonna cost ya....
    From what I see of most tuners, they throw a wideband on it and if the A/F is good, they don't touch it....if it's off all the way across, they do a simple fp adjustment...if it's off in one point they do it in the ecu. If that's good, then they check base timing....they might add a few degrees of total and see if that helps, that's about it as far as I know.
Share This Page
