I own a 1988 GT. Up until recently, it ran perfect. We did a basic tune-up on it, plugs, wires, distributor cap, rotor. (we changed from Split Fire Plugs to Motorcrafts)
Over the past couple of weeks, the car lost power, now it is hard to turn over, backfiring through the manifold, and dies out after a couple minutes of idling.
We used an OBD on it, but can't find the common thread in the 3 codes we got.
Coolant temp sensor voltage low or grounded
Air charge temp or vane air temp sensor too low
Throttle position sensor voltage too low.
We've rechecked the wires so many times I lost count, set the timing to +12 TDC, what is causing all of this???
