Expired 1989 Mustang Gt, And Boss 427 Shortblock
Discussion in 'Fox WTB/Trade Cars & Parts' started by FastSmitty, Feb 15, 2013.
Thread Status:
  1. 1989 Gt converted to 86 nose, an boss 427 shortblock for sale
    Well To start off I have a folder full of over $25k+ in recipts... Car Never Wrecked Ill do a brush strokes of every main part of the car.
    12,500 OBO on the car.
    Engine
    351 Windsor bored .030 Over so 357 Cubes
    AFR 205 heads
    Comp cams 282HR Cam
    1.7 roller rockers
    1 5/8 in shorrty headers
    Brand new Flowmaster cat back put on with Tail pipes
    MSD 6A
    Drag racing 10.5mm plugs and wires.
    After market fuel lines
    Suspension
    FULL TEAM Z MOTORSPORT SUSPENSION..... YES THE $3000 KIT
    Transmission
    ART CARR C4 Build to handle 1000HP
    3800 TQ converter
    Transbrake
    1/4 stick
    hurst shifter
    MOSER 28 SPLINE AXELS
    4x 4 lug cobra R's w/ tires
    2x 4 lug Draglites 15x3.5 w/ skinnys
    2x 4 lug draglites 15x10 w Drag Radials
    Body Is straight, no rust, just needs paint to make the car match, Saleen wing.
    Interior
    AFM PMS 4 Tuner... ($1000) alone....
    Needs some work, I im in the process of installing black Carpter for the cab and ttrunk and back of rear seats.
    Driver and passenger Corbeau Seats, Corbeau Upolstery ready to put on Back seats and install back seats
    I am sure there is much more I am for getting....
    $4,800 OBO
    Ford Racing M-6009-427F Ford Racing Short Blocks
    427 cubic inches
    Boss 4-bolt main block M-6010-BOSS35195 9.5" deck height
    Mahle forged aluminum 4.125" bore pistons with valve reliefs for Z304, N351, GT-40 and other inline valve Windsor cylinder heads. 17cc effective dish volume, check piston to valve clearance
    0.005" below piston to deck height nominal
    SCAT 4.000" stroke forged steel crank
    SCAT forged steel H beam connecting rods with floating pin
    Hydraulic roller camshaft compatible
    Neutral Balance rotating assembly
    Recommended cylinder head fasteners M-6065-BOSS head bolts, M-6014-BOSS studs, or M-6014-Z304 studs, depending on application
    Designed for M-6049-X306//X307/C3/D3/Z304DA cylinder heads. Not designed for production 302/351W or M-6049-Y302/Y303/X302/X303/X304/X305 cylinder heads
    Assembled and ready for your heads, cam and timing chain set
    Requires head gaskets M-6051-R351
    Built with all NEW PARTS
    Parts that can go with motor for extra $ as a package deal
    Timing Set
    Howards Cams Double Roller Billet Steel Timing Sets 94312 - SummitRacing.com
    Crank Pulley Spacer
    Ford Racing Crankshaft Pulley Spacers M-8510-A351 - SummitRacing.com
    Ford Racing 0 Balance Damper
    Ford Racing Crankshaft Damper Assemblies M-6316-D302 - SummitRacing.com
    Canton Oil pan
    Canton Racing Street/Strip Wet Sump Oil Pans 15-690 - SummitRacing.com
    Bullet Cam
    .600/.600
    Everything BNIB
    Package Deal $6,000
    Im Located in Beaverton Oregon, Can do local pick up or you can figure out shipping...
    Please no tire kickers Serious offers only
Thread Status:
