What port? From the install instructions for your kit, the fitting that you show in the picture (below) that is interfering with the distributor does not get installed right there. It should be installed at the back of the rail (for the crossover) and a plug should be installed at the front.
This picture (from LMR's website) shows your fuel inlet and fuel return line on the passenger side
As far as the mounting holes not lining up I don't know what to say, you have not provided clear pictures of that issue. It's possible you got sent the wrong part?
Here are some more pictures. I understand that they normally have a plug on the driver side front. That still does not negate the fact that the distributor is in the way stock and aftermarket. I want to run a different set up. The passenger side mounting holes do not line up. The pictures are with the injectors installed also. The holes are just dont line up. I can fix this. The driver side the distributor is in the way. The picture you put up is not the same rail set up. But even having a plug on the driver side it still gets in the way.
There is not port on the side of the rail for a set up like the picture you put up.
The first three pics are of the passenger side. Then the next three are the distributor in the way. The next two are the driver side. The holes line up. The last two are the passenger side. I can make things work the but point of the post is that the fuel rails are not a very good design and well made.
