1991 Ford Mustang Gt with a 351 bored .060 over with forged internals and h beam rods. a custom ground nitrous cam hardened pushrods from comp and roller lifters from comp. crane cam roller rockers with inconnel exhaust and severe duty intake valves. windsor jr. heads have been ported and polished. edelbrock performer rpm intake ported and polished with a 1 inch spacer. 30lb. injectors. 75mm throttle body 140 amp alternator. under drive pulleys. long tubes H pipe and dynomax race bullets dumped. lakewood shatterproof bellhousing with spec stage 3 clutch and a tremec trans. driveshaft loop. pro 5.0 shifter. aluminum driveshaft with 4:10 gears and moser axles. 255lph fuel pump and msd ignition. has steeda drag launch kit with kyb adjustables and steeda upper and lower control arms with wild rides battle boxes. autometer gauges. subframes and strut tower brace aluminum radiator with electric fan and line lock. also has a ssbc rear disc brake conversion. and a 3 inch cowl hood .
Interior is a mint condition black interior with three gauges oil press. water temp. and a tach with shiftlite.
The whole drivetrain and suspension has about 3,000 miles on it.
