Located in Richardson, TX just north of Dallas. And I'm looking for about $15,500. 1999 Silver Mustang GT with an 04 cobra conversion. Cobra block and internals have about 6k miles on it. Heads and intake came off of an 04 Mach 1 crate motor. T-56 6-Speed. 12 lbs Pro Charger with 3 core inter cooler. All of this was done less than a year ago. The Mach 1 parts and T-56 were brand new. The Cobra block had about 4k miles on it going in. So the entire drive train, including exhaust, has less than 7k miles on it. Car puts down 443 with pump gas on conservative tune. Race gas and aggressive tune puts down over 450hp. Car also has complete set of 03-04 cobra leather and suede seats. MP3 Sony CD, Ford factory alarm. Title in hand. Other mods include K&N air-filter Steeda Tri-Ax Shifter Steeda Clutch Adjuster Kit Steeda Sub-Frame Connectors Steeda 3-Bolt Caster Camber Plates Ford Racing 3.55" rear end gear set Ford Racing Aluminum Fly Wheel Ford Racing 39# injectors (Blue) BBK 1.5" Hi-Performance Lowering Springs BBK Heavy-Duty Upper & Lower Control Arms BBK Ceramic Coated Long tubes Tokico Illumina 5-Way Adj Front Struts Tokico Hi-Performance Rear Struts Ram HD Performance Clutch Kit 160 Degree Thermostat 2000 Mustang Cobra R hood High Performance Oil Pan SCT Performance Chip Cobra Brakes with Red Power Coated Calipers 13" Power Stop Rotors 4 Stainless Steel Brake Lines With high flow cats that will pass emissions without any trouble. Gets 23 MPG in 6th gear doing 70MPH. Comes with extra rims with 2 275/40/ZR17 Nitto 555R Extreme Drag Radials Car is not perfect, could use a little work (like the trunk carpet needs to be replaced and the rear end needs to be rebuilt if you want to drag race it). Email me with questions or if you want to come see it. jhammy49@hotmail.com
