This fall/winter Iam planning a rebuild for my 89. I bought a rebuilt shortblock for a good price not to long ago that I will be taking apart just to make sure everything is ok. It is a stock rebuild with a custom grind Comp cam. Specs of engine are:
"1990 5.0ho block, forged piston, stock crank and rods, melling hv oil pump and pickup, arp pump shaft, edelbrock timing set dual roller, timing cover, new water pump, all new bearings and seals, block was cleaned and inspected at the machine shop, comp custom grind cam, roller lifters, and pushrods
cam specs int. exh.
gross valve lift .513 .513
[email protected] 224 230
adver. duration 276 282
lobe seperation 114.0"
Iam currently running a Powerdyne at 6 psi, edelbrock performer intake, 70 mm tb, full exhaust, roller rockers, etc.....As far as I know stock heads. Now Iam looking to make around 425 rwhp and run high 11's. Iam debating between Twisted wedges and AFR's, and not sure if my intake will be enough. Hopefully I will be swapping out the powerdyne for a S trim at the same time. I have seen many different combos but Iam not 100% sure what is right for me. Remember I want to keep the power below the block splitting point so if say a Novi 1000 is enough(without overspinning it), or keep running the powerdyne with a 2.93 pulley is a good idea let me know. Another thing is head gaskets, with running a supercharger what are the BEST headgaskets to use and what material are they made with. Thanks
cam specs int. exh.
