My buddy has a 302 .30 over afr 185's Vortech 5psi supercharger. 30lbs inj. fuel pressure with vac. line off in 40. Has a 255 fuel pump. FMU. Timing is set to 10' .The car will not idle for ****. TPS is set at .99. Base idle is around 800rpm. Idle starts surgeing up and down then shuts off. Driving the car and coming to a stop the car with die unless giving it some gas then it will smooth out for a min. Any idea's? Does he also need bigger injectors? Maybe 42's? Thanks for any help.
