347 AOD?
88347lx
oly. wa.
Hello all.
I have a 347 project going and am at a point where i need some input from someone that has done this a time or two.
the block is done and assembled, eagle crank, mahle flat tops, RHS 180 aluminum heads.
I will go carb to save BS and am running a kitted AOD and 2500 stall.
I'd like to be able to drive this around without to much trouble so the question is..
How much cam can i put in this thing and still have some street maners?
thanks
Dave
Hello all.
thanks
Dave
i was thinking the comp stroker cam but what do you think?
Are you still running a lock up convertor or is it non lock up? Looking for an off the shelf grind cam or a custom cam? What are your goals? any power adder?
