350 Rwhp with this combo????
Discussion in 'Race Tech' started by tbird187, Jan 17, 2004.
  1. tbird187 Founding Member
    May 29, 2002
    Message Count:
    406
    I am wondering if its possible to hit 350 rwhp with this setup.
    Fresh 302 .60 over Flat top pistons
    Comp Xe274H Cam
    66 289 heads 53cc chamber, ported, 1.94/1.6 valves, Roller Rockers
    Edelbrock F4b Intake, Edelbrock 1406 Carb
    Edelbrock 100 shot wet kit
    Mac equal length Shorties, prochmaber mid pipe, pro dumps,
  2. 50Dreamer Founding Member
    Nov 15, 2000
    Message Count:
    680
    Holy ***** .060 is a lot to take off if i remember correct. You could see some high heat from that. 350hp is possible with the combo but im thinking your gonna have problems with heat. Good luck though
  3. tbird187 Founding Member
    May 29, 2002
    Message Count:
    406
    I didn tknow heat would be an issue is there anyway to help it?
  4. sldghmr Member
    Jun 30, 2003
    Message Count:
    293
    My understanding is that .060 over is as large as you can bore safely, before haveing serious problems. Hopefully one of the true engine gurus will spot this and reply about the possible power levels. My belief is that you should be able to surpass 350 w/the nitrous kit.
  5. 12sec67 Active Member
    Oct 7, 2003
    Message Count:
    1,357
    36
    you'll be under carbed without the nitrous....at least step to the 750 edelbrock. see sig i'm pullin approx 310rwhp through an AOD.
  6. 87gtboy1984 Founding Member
    Feb 12, 2002
    Message Count:
    289
    no your not :rlaugh: j/k tbird i'd say listen to what 12sec67 says... i get ran by him all the time and he knows what he's talking about
Share This Page
