- Mar 25, 2006
- 12
- 0
- 0
parts to build a mild 351W street engine: block has been tapped for screw in freeze plugs, its a E4 (1984) block, heads are DOOE which are the same as 69 windsor heads, they have been machined for screw in studs and one head has had exhaust port work done, the other one was never finished. crank was turned but has surface rust on it now. New parts include: .030 over hypereutectic pistons, rings, michigan 77 rod bearings, michigan 77 main bearings, new cam bearings, new in box edlebrock torker 2 intake, ford racing cam M6250-A351 236/246 dur, 520/538 lift, 115 lobe separation, also have double valve springs, and spring retainers, push rod guide plates, have a set of the stronger truck connecting rods, and a set of ARP rod bolts, ford racing harmonic balancer M3616-C351, gasket set. over $1000.00 in new parts, selling all for $850.00 may part out.
404-732-6550
404-732-6550
