The yellow wire comes from the other plug. It just uses the stud as a power source. It DOES NOT replace the 4 gauge wire. The 4 gauge wire still goes from the stud to the starter solenoid.Skoobie said:This post is getting very detailed The only discrepency I've found is 89 Sleeper says to connect the yellow wire to the stud. Is this something that everyone else failed to mention? It seems that if a 10g wire is in danger of burning up from the new alt that the little yellow wire would go up like a match stick is that amprage was run through it
8950HO said:Did those lugs on the 4ga cable come already attatched or did you crimp them yourself,properly of course,not in a vise?
89sleeper said:The best way is to use a torch and use a little flux to clean the lug, the fill it up with solder and stick the wire in and let it cool. Thats what I did and it worked great. Crimping it does not get as good of a connection.
Actually the manufacturers of the battery cable eyelets recommend crimping,using a professional heavy duty crimper instead of soldering.
Soldering is a pita and the connection is not as good and the resistance is probably higher using solder.
Those heavy duty crimpers crimp the wire so tightly that there is no air space between the wires resulting in a solid copper to copper connection.
Soldering was very easy for me.8950HO said:Actually the manufacturers of the battery cable eyelets recommend crimping,using a professional heavy duty crimper instead of soldering.
