- Jan 30, 2015
- 12
- 0
- 1
I recently replaced my stock alternator with the 3G 130 amp kit from LMR and was wondering what sort of change I should expect to see at the dash mounted battery gauge? With the old alternator, the gauge always read low and is what prompted me to upgrade, thinking it was about shot. Though the car never failed to start or presented any electrical problems. With the new alt. the gauge goes to the center at times, but still tends to read lower than I think it should.
I have taken voltage readings with a VOM at the battery both before and after changing alternators. With the engine running and the old alternator, was only reading 12.5 volts. With new alternator, now reading 13.5 volts...still not at 14.5 volts I would expect from a high octane alternator. I don't think its a gauge issue, I notice it changing while I am driving. I look down at times now and it is in the center, something it never did before. But I can also look down and it will be reading low. It also drops when I turn on the lights or heater blower.
The kit was installed with the upgraded 60 wire and went in with no issues. Seems to work better than the old alternator. Was wondering if this a battery issue, something else, or just normal?
