Ok... I've been bending jrichker's ear about this setup but I think he's logged for the night. I'll attempt to make this short.
My alternator bit the dust last night. I've been looking into upgrading to 130 amp and have read condradicting instructions for the upgrade. Some suggest that it is DANGEROUS to connect the two black/orange wires to the 3G in the event that the fuse blows on the new power wire. They say that if the fuse on the new power wire blows that the 2 10AWG wires will burn up and potentially cause a fire. Great, I can deal with that logic. The problem is that others say, that if those wires are NOT connected that the charging system will not work because those wires are required to have power for voltage sensing. So which is it? Do they need to be hooked up to the alt or not?
Next: Best I can figure, my car came with not 3, but a 2 wire voltage regulator setup (see the pic).
Now... PA performance has what they call a 120 amp, 2 wire regulated, 2G replacement alternator. It requires no bracket modification and I assume uses all of the stock connections. It does not however, provide many details on the alternator. I have no idea if this 120A 2G replacement has "posts" on the back like the 3G does. If it does.... GREAT! It should make installation that much easier but still does not solve the issue with having (or not having) to hook the stock black/orange wires up to the new alt.
So... Am I correct in assuming that I have the 2 wire regulator setup?
If not, which of the wires do I need to pigtail for the stator wire? (there is no white/black)
Has anyone installed one of these 2G replacements?
Do the black/orange wires get hooked to the new alt or not?
If not... will the charging system still function correctly with just the new power wire run out to the positive side of the start solenoid?
Thanks all.
Thanks all.
