4-speed
http://www.davidkeetoploaders.com/toploaderhistory.htm
Ford T-10: http://omaha.craigslist.org/pts/480851743.html
And these sites are good reference:
http://www.toploaderheaven.com/
http://www.hanlonmotorsports.com/
http://www.ddperformance.com/
The Borg-Warner T-10 is a GM transmission today. T-10, Super T-10
http://www.tbtrans.com/t10_transmission.htm
Now, this is what I found surfing around. Someone may certainly know something about the T-10 that I don't. But you may be much happier with a T-5 conversion, which will put a 5 speed trans in your 66. You certainly don't want an original Ford T-10, but you may want a Ford Toploader. For what a Toploader will cost you, you could do a T-5 for not much more. There are still deals to be had on Toploaders though, just harder to find these days.
Do some reading and post back.
Thanks a lot for the information. My impression is that the GT350's used the Ford toploader. I think I'll shoot for the real thing. Do you think that T-10's were used on 4-speed Mustangs in the '65, '66 era ?
Hipobuzz
Hipobuzz
I think the GT350's did use toploaders and the other stangs used T-10's.
The 65's and earlier used T-10's. I don't know that a current T-10 will bolt up to a Ford Bellhousing. You can still find the Ford T-10 occasionally. If you do, make sure you get the slip yoke for the drive shaft with it. It's got an odd-ball 25 spline output shaft, as do the early Toploaders
Hipobuzz
Toploaders were introduced on the Mustang in 1965 (although the 25 spline units used in 65 were NOT very strong--the toploader was strengthened the next model year). T-10s were most common in 1965 and early 66 but by mid-year 1966 the toploader would mostly replace the T-10. GM continued to used the Borg Warner T-10 for years.
Shelby, however, used the T-10, not the toploader for the 1965 GT-350. The T-10 was fitted with an aluminum tailhousing and was relatively light. Obviously it handled a decent amount of power, too. By 1966, the Shelby would come with the toploader if you ordered a 4 speed.
My A code 1966 Mustang (San Jose built November/December 65) came with a T10, which I have since replaced with a T5z. The T10 served its purpose well--very smooth shifts and was still going strong after 1 rebuild (with updated synchros) and 400,000 miles when I pulled it. Fuel mileage and long trips trumped originallity for me, though, or I would have kept it.
My advice: If you are adding a stick shift go directly to a T5 or a Tremec 3650. The overdrive will continue paying for itself as fuel prices rise even higher. I can pull mid-20s now on the highway, even with an old school 4100 4 barrel carburetor and Stealth intake and testosterone-influenced speeds. Unless you have a hyperkinetic build on your small block, the T5 will last a long time and can look quite stock to casual observers, especially if you keep your 4 speed shift ball and use a repro t-handle.
