5.0 distributor
Discussion in 'Fox 5.0 Mustang Tech' started by kccoon1, Apr 12, 2009.
  1. how can you test to see if a distributor is bad
  2. From Cranks OK, but No Start Checklist for Fuel Injected Mustangs...
    PIP sensor in distributor: The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A noid light will tell if the PIP is working by flashing when the engine is cranking. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing when the engine is cranked using the ignition switch.
    A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
    Revised 8-Mar-2009 to add test for TFI module
    1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
    A.) MSD or Crane ignition box if so equipped
    B.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
    C.) Coil
    D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
    E.) No ECC or computer power - ECC or computer relay failure
    86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
    F.) No ECC or computer power - fuse or fuse link failure
    86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
    G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse or fuse link is blown.
    Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
    Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
    H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness
    I.) Computer.
    J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
    K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
    See the following links for wiring diagrams...
    AutoZone.com | Get In The Zone! for 79-88 model Mustangs
    Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
    Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
    Ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715f.gif
    Computer/fuel pump wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif[
    Ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167163.gif
    AutoZone.com | Get In The Zone! for 89-93 model Mustangs
    Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
    Computer/fuel pump/ignition wiring diagram, 91-93 cars
    http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
    http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
    2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
    B.) Distributor cap
    C.) Rotor
    D.) Spark Plug wires
    Two reasons:
    Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
    [​IMG]
    If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
    C.) Clogged fuel filter
    D.) Failed fuel pump
    A.) A noid light available from any auto parts store, is one way to test the injector wiring.
    The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
    B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
    D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
    E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
    F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
    G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
    It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
    6.) Spark & fuel pressure OK.
    A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
    C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
    HO & 351W 1-3-7-2-6-5-4-8
    Non HO 1-5-4-2-6-3-7-8
    E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
  3. distributor problems
    I PUT A NEW DISTRIUTOR IN MY 90 MUSTANG AND IT BACKFIRES WHEN I TRY TO START,WHAT COULD BE THE PROBLEM
  4. HOW DO YOU KNOW IF YOU HAVE THE PLUG WIRES ON THE DISTRIBUTOR CAP IN THE WRIGHT POST.I CHANGED THE DISTRIBUTOR TO A BILLET AND I CAN'T GET IT TO START,THE ENGINE WILL SPIN AND BACKFIRE,COULD THE DISTRIBUTOR BE IN THERE WRONG?
  5. Non-tuning issue - moved to 5.0 Tech.
    Less caps, please. How did you locate the rotor when swapping the distributor? Did you make sure to use the correct firing order?
  6. ON THE FIRING ORDER WILL THE #1 SPARK PLUG BE ON THE DRIVERS SIDE OR THE PASSENGER SIDE ,THIS IS THE FIRST TIME I'VE REPLACED A DISTRIBUTOR
  7. Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole,
    crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer
    on the engine block.
    The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor
    to about 11:00, since it will turn clockwise as it slides into place.
    Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block,
    (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing.
    If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards
    or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor,
    but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't
    align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too
    far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
    At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car
    runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back
    in when you finish.
    The HO firing order is 1-3-7-2-6-5-4-8.
    Non HO firing order is 1-5-4-2-6-3-7-8
    [​IMG]
  8. chill with the caps please..
  9. thanks for the help
  10. Yeah, I pulled the distributor off my car for my pending h/c/i swap - without marking it - so this helps me too, so thanks!
  11. Did you set the timing properly??
  12. 180 degrees out, swap the distributor. Spin it 180* and it should be better.
  13. Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole,
    in when you finish.
    [​IMG]
  14. Please stop posting multiple threads on the same topic, including across multiple forums. I just merged three of your threads together and moved one out of Fox 5.0 Tuning into this thread, since it's still not a tuning issue, like it wasn't when I moved your other thread on the 12th. This appears to be a continuation of your thread about testing if a distributor is bad, since it's on the same topic and suddenly a month later, you replaced it.
    Please follow jrichker's post verbatum and post back if you're still having issues.
