I'm going to do a 5 speed conversion on a 94 with a v6.
Some things I'm not sure about.
Is the driveshaft length the same between the automatic and manual cars?
Does the v6 use the same manual bellhousing as the v8, or is it different?
Is the transmission "bolt-in" interchangable between the v6 and v8? If not, what is different between them, can one be converted to work in the other?
Is the transmission crossmember different?
And anything else that I would need to know, thanks!
